Hi everyone, I’m currently working on the Rosject referring to the course ROS2 C++ Humble. The whole code works perfectly fine in the simulation, but with the actual robot I’m having a problem. When I launch the nodes, the robot should first use service I created to find the wall, but for some reason it can’t function properly and keeps rotating. Moreover, even when I kill the nodes and try to use the keyboard to control it, the robot still keeps rotating for a while. You can see the problem in the video linked below.
Here below I will let the codes I’m using.
The move_robot_service_action_v1.cpp, this script is responsable for calling the client and the action and moving the robot near the wall.
#include "custom_messages/action/odom_record.hpp"
#include "custom_messages/srv/detail/find_wall__struct.hpp"
#include "custom_messages/srv/find_wall.hpp"
#include "geometry_msgs/msg/twist.hpp"
#include "rcl/node_options.h"
#include "rclcpp/rclcpp.hpp"
#include "rclcpp_action/rclcpp_action.hpp"
#include "sensor_msgs/msg/detail/laser_scan__struct.hpp"
#include <chrono>
#include <sensor_msgs/msg/laser_scan.hpp>
#include <chrono>
#include <cstdlib>
#include <future>
#include <inttypes.h>
#include <iostream>
#include <memory>
#include <thread>
using FindWall = custom_messages::srv::FindWall;
class MoveRobot : public rclcpp::Node {
public:
float vx;
float vz;
using OdomRecord = custom_messages::action::OdomRecord;
using GoalHandleOdomRecord = rclcpp_action::ClientGoalHandle<OdomRecord>;
explicit MoveRobot(
const rclcpp::NodeOptions &node_options = rclcpp::NodeOptions())
: Node("move_robot_service_action_node_v1", node_options),
goal_done_(false) {
// Initialize the MutuallyExclusive callback group object
callback_publisher_moverobot_group_ = this->create_callback_group(
rclcpp::CallbackGroupType::MutuallyExclusive);
callback_action_moverobot_group_ = this->create_callback_group(
callback_subscriber_moverobot_group_ = this->create_callback_group(
rclcpp::SubscriptionOptions options1;
options1.callback_group = callback_subscriber_moverobot_group_;
publisher_ =
this->create_publisher<geometry_msgs::msg::Twist>("cmd_vel", 10);
timer_ = this->create_wall_timer(
500ms, std::bind(&MoveRobot::timer_callback, this),
callback_publisher_moverobot_group_);
subscription_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
"scan", 10,
std::bind(&MoveRobot::topic_callback, this, std::placeholders::_1),
options1);
this->client_ptr_ = rclcpp_action::create_client<OdomRecord>(
this->get_node_base_interface(), this->get_node_graph_interface(),
this->get_node_logging_interface(),
this->get_node_waitables_interface(), "record");
this->timer_action_ = this->create_wall_timer(
std::chrono::milliseconds(500), std::bind(&MoveRobot::send_goal, this),
callback_action_moverobot_group_);
bool is_goal_done() const { return this->goal_done_; }
void send_goal() {
using namespace std::placeholders;
this->timer_action_->cancel();
this->goal_done_ = false;
if (!this->client_ptr_) {
RCLCPP_ERROR(this->get_logger(), "Action client not initialized");
if (!this->client_ptr_->wait_for_action_server(std::chrono::seconds(10))) {
"Action server not available after waiting");
this->goal_done_ = true;
return;
auto goal_msg = OdomRecord::Goal();
RCLCPP_INFO(this->get_logger(), "Sending goal");
auto send_goal_options =
rclcpp_action::Client<OdomRecord>::SendGoalOptions();
send_goal_options.goal_response_callback =
std::bind(&MoveRobot::goal_response_callback, this, _1);
send_goal_options.feedback_callback =
std::bind(&MoveRobot::feedback_callback, this, _1, _2);
send_goal_options.result_callback =
std::bind(&MoveRobot::result_callback, this, _1);
auto goal_handle_future =
this->client_ptr_->async_send_goal(goal_msg, send_goal_options);
private:
void timer_callback() {
auto message = geometry_msgs::msg::Twist();
message.linear.x = 0.1;
message.angular.z = vz;
publisher_->publish(message);
void topic_callback(const sensor_msgs::msg::LaserScan::SharedPtr msg) {
std::this_thread::sleep_for(250ms);
float Foward1 = msg->ranges[360];
float Right = msg->ranges[180]; // 180
float Left = msg->ranges[520]; // 520
vx = 0.2;
if (Right > 0.3 && Foward1 > 0.5) {
vz = -0.2;
} else if (Right < 0.2 && Foward1 > 0.5) {
vz = 0.2;
} else if (Right < 0.3 && Right > 0.2 && Foward1 > 0.5) {
vz = 0;
} else if (Foward1 < 0.5) {
vz = 1;
/*RCLCPP_INFO(this->get_logger(),
"Foward: '%f'. Right: '%f'. Left:'%f'. Vz '%f'", Foward1, Right,
Left, vz);*/
// Action client functions
void goal_response_callback(
std::shared_future<GoalHandleOdomRecord::SharedPtr> future) {
// this is necessary because the system uses ros2 foxy e not humble
auto goal_handle = future.get();
if (!goal_handle) {
RCLCPP_ERROR(this->get_logger(), "Goal was rejected by server");
} else {
"Goal accepted by server, waiting for result");
void feedback_callback(
GoalHandleOdomRecord::SharedPtr,
const std::shared_ptr<const OdomRecord::Feedback> feedback) {
RCLCPP_INFO(this->get_logger(), "Feedback received: %f",
feedback->current_total);
void result_callback(const GoalHandleOdomRecord::WrappedResult &result) {
switch (result.code) {
case rclcpp_action::ResultCode::SUCCEEDED:
break;
case rclcpp_action::ResultCode::ABORTED:
RCLCPP_ERROR(this->get_logger(), "Goal was aborted");
return;
case rclcpp_action::ResultCode::CANCELED:
RCLCPP_ERROR(this->get_logger(), "Goal was canceled");
return;
default:
RCLCPP_ERROR(this->get_logger(), "Unknown result code");
return;
// possivelmente vou printar um a um
for (int i = 0; i < result.result->list_of_odoms.size(); ++i) {
/*RCLCPP_INFO(this->get_logger(), "X: %f. Y: %f. Theta: %f",
result.result->list_of_odoms[i].x,
result.result->list_of_odoms[i].y,
result.result->list_of_odoms[i].z);*/
std::cout << "Dado salvo: " << i + 1 << std::endl;
std::cout << "X: . " << result.result->list_of_odoms[i].x << std::endl;
std::cout << "Y: . " << result.result->list_of_odoms[i].y << std::endl;
std::cout << "THETA: . " << result.result->list_of_odoms[i].z
<< std::endl;
rclcpp::TimerBase::SharedPtr timer_action_;
rclcpp::Publisher<geometry_msgs::msg::Twist>::SharedPtr publisher_;
rclcpp::Subscription<sensor_msgs::msg::LaserScan>::SharedPtr subscription_;
rclcpp_action::Client<OdomRecord>::SharedPtr client_ptr_;
bool goal_done_;
rclcpp::CallbackGroup::SharedPtr callback_action_moverobot_group_;
rclcpp::CallbackGroup::SharedPtr callback_subscriber_moverobot_group_;
rclcpp::CallbackGroup::SharedPtr callback_publisher_moverobot_group_;
class ServiceClient : public rclcpp::Node {
private:
rclcpp::Client<FindWall>::SharedPtr client_;
rclcpp::TimerBase::SharedPtr timer_client_;
bool service_done_ = false;
void timer_client_callback() {
while (!client_->wait_for_service(1s)) {
if (!rclcpp::ok()) {
RCLCPP_ERROR(
this->get_logger(),
"Client interrupted while waiting for service. Terminating...");
return;
"Service Unavailable. Waiting for Service...");
auto request = std::make_shared<FindWall::Request>();
auto result_future = client_->async_send_request(
request, std::bind(&ServiceClient::response_client_callback, this,
std::placeholders::_1));
void response_client_callback(rclcpp::Client<FindWall>::SharedFuture future) {
auto status = future.wait_for(1s);
if (status == std::future_status::ready) {
RCLCPP_INFO(this->get_logger(), "Result: success");
service_done_ = true;
} else {
RCLCPP_INFO(this->get_logger(), "Service In-Progress...");
public:
ServiceClient() : Node("service_client") {
client_ = this->create_client<custom_messages::srv::FindWall>("findwall");
timer_client_ = this->create_wall_timer(
1s, std::bind(&ServiceClient::timer_client_callback, this));
bool is_service_done() const { return this->service_done_; }
int main(int argc, char *argv[]) {
rclcpp::init(argc, argv);
auto service_client = std::make_shared<ServiceClient>();
while (!service_client->is_service_done()) {
rclcpp::spin_some(service_client);
// RCLCPP_INFO(rclcpp::get_logger("rclcpp"), "ele chegou ate aqui");
// After the robot found the wall it will start moving and call the service
std::shared_ptr<MoveRobot> move_robot_service_action_node =
std::make_shared<MoveRobot>();
// Initialize one MultiThreadedExecutor object
rclcpp::executors::MultiThreadedExecutor executor;
executor.add_node(move_robot_service_action_node);
executor.spin();
rclcpp::shutdown();
return 0;
This is the service server: find_wall_server.cpp
#include "rclcpp/executor.hpp"
#include "rclcpp/executors.hpp"
#include "rclcpp/parameter_service.hpp"
#include "rclcpp/utilities.hpp"
#include "sensor_msgs/msg/laser_scan.hpp"
#include <chrono>
#include <unistd.h>
#include <algorithm>
#include <functional>
#include <iostream>
#include <memory>
#include <thread>
using namespace std;
using std::placeholders::_1;
using std::placeholders::_2;
class ServerNode : public rclcpp::Node {
public:
ServerNode() : Node("find_wall_server_node") {
callback_service_group_ = this->create_callback_group(
callback_subscriber_group_ = this->create_callback_group(
rclcpp::SubscriptionOptions options_sub;
options_sub.callback_group = callback_subscriber_group_;
srv_ = create_service<FindWall>(
"findwall", std::bind(&ServerNode::findwall_callback, this, _1, _2),
rmw_qos_profile_services_default, callback_service_group_);
publisher_ =
"scan", 10,
std::bind(&ServerNode::topic_callback, this, std::placeholders::_1),
options_sub);
private:
void findwall_callback(const std::shared_ptr<FindWall::Request> request,
const std::shared_ptr<FindWall::Response> response) {
// response->wallfound = false;
final_position = false;
// RCLCPP_INFO(this->get_logger(), "Final_Position: %d", final_position);
while (final_position != true) {
if (Foward > min_distance + 0.05 && min_distance >= 0.30) {
// Send velocity to move the robot to the right
vx = 0;
vz = -0.2;
} else if (Foward <= min_distance + 0.05 && Foward >= 0.25) {
// Send velocity to move the robot foward
vx = 0.1;
vz = 0;
} else {
vx = 0;
vz = -0.2;
if (Right <= min_distance + 0.05 && min_distance <= 0.25) {
vx = 0;
vz = 0;
this->twist_msg.linear.x = vx;
this->twist_msg.angular.z = vz;
this->publisher_->publish(this->twist_msg);
response->wallfound = true;
// break;
final_position = true;
// RCLCPP_INFO(this->get_logger(), "Ele entrou aqui");
// final_position = false;
Foward = msg->ranges[360];
min_distance = 100;
// finding the minimal value
for (int i = 0; i < 720; i++) {
if ((msg->ranges[i] <= min_distance) &&
(msg->ranges[i] >= msg->range_min) &&
(msg->ranges[i] <= msg->range_max)) {
min_distance = msg->ranges[i];
position = i;
"Foward: '%f'. Right: '%f'. Min: '%f'. position: '%d'", Foward,
Right, min_distance, position);*/
float Foward;
float Right;
float min_distance;
float vx;
float vz;
bool final_position;
int position;
rclcpp::Service<FindWall>::SharedPtr srv_;
geometry_msgs::msg::Twist twist_msg;
rclcpp::CallbackGroup::SharedPtr callback_service_group_;
rclcpp::CallbackGroup::SharedPtr callback_subscriber_group_;
std::shared_ptr<ServerNode> server_node = std::make_shared<ServerNode>();
executor.add_node(server_node);
executor.spin();
rclcpp::shutdown();
return 0;
And the launch file:
return LaunchDescription([
Node(
package='wall_service_pkg',
executable='find_wall_server',
output='screen'),
Node(
package='action_service',
executable='action_server_node',
output='screen'),
Node(
package='topic_publisher_pkg',
executable='move_robot_service_action_node_v1',
output='screen')
I didn’t put the other scripts like the action server and the CMakeLists because there are already a lot of information, and I think that if the problem was in these files, the simulation wouldn’t work properly, but it does. But if anyone thinks it is important, I can add them.
