Problems with ROS2 C++ Project Part 2
Hello
I am currently at part 2 of the ros2 c++ project.
I have somehow issues to run the subscriber callback and the service server callback simultanously.
This means. That when I run my code.
The service callback gets called. But the subscriber callback gets not called. Which means I don’t get the logs which should appear from the subscriber callback, while as my service callback gets stucked in the while loop, because it waits for a valid feedback of the subscriber.
I don’t know what the issue could be, since in the Topics_Quiz it has worked fine to call the subscriber callback.
This is my code:
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/int32.hpp"
#include "geometry_msgs/msg/twist.hpp"
#include "sensor_msgs/msg/laser_scan.hpp"
#include "my_ros2ject/srv/find_wall.hpp"
#include <chrono>
#include <memory>
#include <thread>
using FindWall = my_ros2ject::srv::FindWall;
using std::placeholders::_1;
using std::placeholders::_2;
using namespace std::this_thread; // sleep_for, sleep_until
using namespace std::chrono;      // nanoseconds, system_clock, seconds
class Find_Wall : public rclcpp::Node
public:
  Find_Wall() : Node("find_wall")
    // Create a subscriber to the "scan" topic with a queue size of 10
    subscriber_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
      "scan", 10, std::bind(&Find_Wall::laserscan_callback, this, _1));
    // Create a publisher to the "cmd_vel" topic with a queue size of 10
    publisher_ = this->create_publisher<geometry_msgs::msg::Twist>("cmd_vel", 10);
    // Create a service named "find_wall" with a callback function
    srv_ = create_service<FindWall>(
        "find_wall", std::bind(&Find_Wall::moving_callback, this, _1, _2));
    // Initialize laserdata
    for (int i = 0; i < 360; i++) {
      laserdata_[i] = 10;
private:
  void laserscan_callback(const sensor_msgs::msg::LaserScan::SharedPtr msg)
    // laserscan callback triggered
    RCLCPP_INFO(this->get_logger(), "Laserscan callback triggered. Number of ranges: %zu", msg->ranges.size());
    // Log the front laser value
    RCLCPP_INFO(this->get_logger(), "Front Laser Value is : '%f'", msg->ranges[180]);
    // Store the laser data in the laserdata_ array
    std::copy(msg->ranges.begin(), msg->ranges.end(), laserdata_.begin());
    // Declare the subscriber, publisher, service and Twist message as private member variables
    rclcpp::Subscription<sensor_msgs::msg::LaserScan>::SharedPtr subscriber_;
    rclcpp::Publisher<geometry_msgs::msg::Twist>::SharedPtr publisher_;
    rclcpp::Service<FindWall>::SharedPtr srv_;
    geometry_msgs::msg::Twist vel_;
    // Create laserdata_ float array
    std::array<float, 360> laserdata_;
  void moving_callback(const std::shared_ptr<FindWall::Request> request,
                     const std::shared_ptr<FindWall::Response> response) {
    RCLCPP_INFO(this->get_logger(), "server_callback started with {}", request.get());
    while (laserdata_[0] == 10) { // Wait until laserdata gets realistic values
        RCLCPP_INFO(this->get_logger(), "laser data not ready");
        sleep_for(1s);
    // Initialize values
    double min_laser = 100000;
    int min_index = 0;
    // Find the minimum laser value and its index
        if (laserdata_[i] < min_laser) {
            min_laser = laserdata_[i];
            min_index = i;
    // Calculate the desired angle (in degrees) for the 180th value to align with the minimum value
    double desired_angle_deg = 180 - min_index;
    // Calculate the time needed for rotation to achieve the desired angle
    double angular_vel = 0.2;
    double rot_angle_rad = desired_angle_deg * 0.01745; // Convert to radians
    double rot_time = rot_angle_rad / angular_vel;
    if (rot_angle_rad < 0) {
      angular_vel = -angular_vel;
      rot_time = -rot_time;
    RCLCPP_INFO(this->get_logger(), "rot time is : '%f'", rot_time);
    RCLCPP_INFO(this->get_logger(), "desired angle is : '%f'", desired_angle_deg);
    RCLCPP_INFO(this->get_logger(), "rot angle rad is : '%f'", rot_angle_rad);
    RCLCPP_INFO(this->get_logger(), "angular vel is : '%f'", angular_vel);
    // Rotate the robot
    vel_.angular.z = angular_vel;
    publisher_->publish(vel_);
    sleep_for(milliseconds(static_cast<int>(rot_time * 1000)));
    vel_.angular.z = 0;
    RCLCPP_INFO(this->get_logger(), "robot has rotated");
    sleep_for(1s);
    if (laserdata_[180] < min_laser + 0.1 && laserdata_[180] > min_laser - 0.1) {
      // Set the response success variable to true
      response->wallfound = true;
    } else {
      response->wallfound = false;
int main(int argc, char * argv[])
  rclcpp::init(argc, argv);
  // Create an instance of the Find_Wall class
  auto node = std::make_shared<Find_Wall>();
  // Create a loop rate of 1 Hz
  rclcpp::WallRate loop_rate(1);
  while (rclcpp::ok()) {
    // Spin once to process any callbacks
    rclcpp::spin_some(node);
    // Sleep to maintain the loop rate
    loop_rate.sleep();
  rclcpp::shutdown();
  return 0;
Does somebody have an idea, what the issue is? It is probably something really silly, which I am overlooking.
Would be very thankful for any help.
Cheers
Hi @Dkae ,
The solution for your problem is very simple. You need to implement Executors and Callback Groups.
In your program you have two callbacks that needs to run in parallel - laser callback and service callback. So classify your callbacks under ReentrantCallbackGroup with MultiTheadedExecutor.
That should fix your problem.
Hi @girishkumar.kannan
Thanks for the advice. Yeah I was thinking about this.
Apperently the create_subscription does’nt have the option to add it to a callback group, so I could just add the create_service
So I implemented it like this, and now it works.
class Find_Wall : public rclcpp::Node {
public:
  Find_Wall() : Node("find_wall") {
    // Initialize one Reentrant callback group object
    callback_group_ =
        this->create_callback_group(rclcpp::CallbackGroupType::Reentrant);
        "scan", 10,
    publisher_ =
    srv_ = this->create_service<FindWall>(
        "find_wall", std::bind(&Find_Wall::moving_callback, this, _1, _2),
        rmw_qos_profile_services_default, callback_group_);
      laserdata_[i] = 10;
private:
  void laserscan_callback(const sensor_msgs::msg::LaserScan::SharedPtr msg) {
  // member variables
  rclcpp::CallbackGroup::SharedPtr callback_group_;
int main(int argc, char *argv[]) {
  // Initialize one MultiThreadedExecutor object
  rclcpp::executors::MultiThreadedExecutor executor;
  executor.add_node(node);
  executor.spin();
  rclcpp::shutdown();
  return 0;
Thanks a lot for your help!
Hi @Dkae ,
create_subscription does have a callback group option. You can do it this way:
// library includes:
#include "rclcpp/qos.hpp"
#include "rmw/qos_profiles.h"
#include "rclcpp/callback_group.hpp"
// main code - subscriber with callback group defined
auto scan_sub_qos = rclcpp::QoS(rclcpp::KeepLast(10), rmw_qos_profile_sensor_data);
rclcpp::SubscriptionOptions scan_sub_options;
scan_sub_options.callback_group = create_callback_group(rclcpp::CallbackGroupType::Reentrant);
scan_sub = this->create_subscription<LaserScan>(
           "/scan", scan_sub_qos,
           std::bind(&WallFollowerRobot::scan_callback, this, std::placeholders::_1),
           scan_sub_options);
Check the documentation for more info: rclcpp: rclcpp::Node Class Reference
