Hello there,
I’m working on a project for college and I’m stuck in what to do next.
The project I’m currently working on is a maze solving robot. Here’s the project details.
First, a camera will be mounted above the maze which will take a picture of the maze, then using an algorithm, I will have to provide the path to the exit of the maze to the robot. Then the robot will have to follow that path to get out of the maze.
So to recap,
1 - A mounted camera above the maze takes a picture of the maze
2 - Image is processed and using an algorithm, and a path is made from the starting location of the robot to the exit location of the maze.
3 - Robot is required to follow the determined path to get out of the maze
For more clarification: https://www.youtube.com/watch?v=Pg15dr6_7GM
This video is pretty close to what I should implement but instead of the sketching part, an algorithm is going to do image processing on the picture taken by camera and determine the path.
Any help regarding how to do this project is much appreciated. I do not even know where to start…
