Hi all, I have created a class to take off, move around and land a drone. The code below worked perfectly when invoked directly.
But when the same class is called from a separate python file using its object, its failed to get past the class’s constructor.
File name: move_drone.py
class move_drone_class:
self.tw=Twist()
#created publisher to move the robot using topic /cmd_vel
self.pub_cmd_vel=rospy.Publisher("/cmd_vel",Twist,queue_size=1)
while self.pub_cmd_vel.get_num_connections() < 1:
print("Waiting on /cmd_vel publisher")
#or use "Pass" here
#create publisher to takeoff using topic /drone/takeoff
self.pub_takeoff=rospy.Publisher("/drone/takeoff",Empty,queue_size=1)
while self.pub_takeoff.get_num_connections() < 1:
print("Waiting on /takeoff publisher")
#or use "Pass" here
#create publisher to land using topic /drone/land
self.pub_land=rospy.Publisher("/drone/land",Empty,queue_size=1)
while self.pub_land.get_num_connections() < 1:
print("Waiting on /land publisher")
#or use "Pass" here
def takeoff(self):
self.pub_takeoff.publish(Empty())
print("Taking Off-----------------")
def land(self):
self.pub_land.publish(Empty())
print("Landing---------------------")
def move_around_in_random(self):
print("Moving Around")
self.tw.linear.x=0.8
self.tw.angular.z=0.8
self.pub_cmd_vel.publish(self.tw)
if __name__ == '__main__':
rospy.init_node("drone_node")
drone_obj=move_drone_class()
#the code below takeoff the drone, moves it around for 3 seconds and then lands it
try:
drone_obj.takeoff()
drone_obj.move_around_in_random()
rospy.sleep(3)
drone_obj.land()
pass
Below snippet is the constructor that the accessing program drone_client.py is not able to get past
#or use "Pass" here
#or use "Pass" here
#or use "Pass" here
The code for drone_client.py, which is the file accessing the class is as below.
import time
import actionlib
from ardrone_as.msg import ArdroneAction, ArdroneGoal, ArdroneResult, ArdroneFeedback
from move_drone import move_drone_class
move_drone_obj=move_drone_class()
nImage = 1
# definition of the feedback callback. This will be called when feedback
# is received from the action server
# it just prints a message indicating a new message has been received
def feedback_callback(feedback):
global nImage
print('[Feedback] image n.%d received'%nImage)
nImage += 1
# initializes the action client node
rospy.init_node('drone_action_client')
print("node initialised")
# create the connection to the action server
client = actionlib.SimpleActionClient('/ardrone_action_server', ArdroneAction)
# waits until the action server is up and running
print("waiting for server connection")
client.wait_for_server()
print("server connected")
# creates a goal to send to the action server
goal = ArdroneGoal()
goal.nseconds = 10 # indicates, take pictures along 10 seconds
# sends the goal to the action server, specifying which feedback function
# to call when feedback received
client.send_goal(goal, feedback_cb=feedback_callback)
# Uncomment these lines to test goal preemption:
#time.sleep(3.0)
#client.cancel_goal() # would cancel the goal 3 seconds after starting
# wait until the result is obtained
# you can do other stuff here instead of waiting
# and check for status from time to time
# status = client.get_state()
# check the client API link below for more info
# client.wait_for_result()
move_drone_obj.takeoff()
while client.get_state()<2:
move_drone_obj.move_around_in_random()
# print(client.ger)
move_drone_obj.land()
print('[Result] State: %d'%(client.get_state()))
The Action server used for the drone was
roslaunch ardrone_as action_server.launch
Let me know if you need more info, the only other topic where i found something similar was
click link
