Hi, i’m doing the 4.4 Topics Quiz about avoiding the wall using Turtlebot.
If i got it right i have to write the whole publisher-subscriber behaviour in the same node aka .cpp script so i’m trying something like this.
ros::init(argc, argv, "topics_quiz_node");
ros::NodeHandle nh;
ros::Subscriber sub = nh.subscribe("/kobuki/laser/scan", 1000, wallAvoiderCallback);
ros::spin();
return 0;
while in my wallAvoiderCallback i’m trying to publish the velocity command based on the distance i sense.
void wallAvoiderCallback(const sensor_msgs::LaserScan::ConstPtr &msg) {
// ROS_INFO("Received %f", msg->ranges[360]); // it works
// defining the command object
geometry_msgs::Twist forward_command;
if (msg->ranges[360] > 1) {
forward_command.linear.x = 0.1;
ros::NodeHandle nh;
ros::Publisher pub = nh.advertise<geometry_msgs::Twist>("/cmd_vel", 1000);
ros::Rate loop_rate(2);
pub.publish(forward_command);
ros::spinOnce();
loop_rate.sleep();
it works for the first 5 seconds and then i get this error which terminates the node.
[topics_quiz_node-1] process has died [pid 38458, exit code -11, cmd /home/user/catkin_ws/devel/lib/topics_quiz/wall_avoider __name:=topics_quiz_node __log:=/home/user/.ros/log/3baf523a-f159-11eb-b55f-0242ac170008/topics_quiz_node-1.log].
log file: /home/user/.ros/log/3baf523a-f159-11eb-b55f-0242ac170008/topics_quiz_node-1*.log
done
Anybody has suggestion about how to complete the quiz? Thank you.
