PYTHON for Robotics: Unit 6: Turtlebot Maze - no Attribute for rotate/ function not found
Hello!
Once again, i can not find the rotate function. Could you please provide a code snippet, so i can manually add it into the class attributes?
Everything else is working perfectly fine…
Yes, i have imported the class and the object…
Yes, i have sourced the virtual environment and workspace…
Thank you!
Here you have the file with all that code: GIT
I’ll Upload this to the project so that users dont have the same issue you had ;). Thanks for the issue reporting :wink:
Already updated in the system.
