I received the following syntax error.
File “robot_control_class.py”, line 150 s = “Moved robot " + motion + " for " + str(time) + " seconds at " str(speed) + " m/s”
SyntaxError: invalid syntax
Hi, yes, you receive an invalid syntax error when your syntax is incorrect.
The + should be in between the strings you are trying to concatenate.
You are missing a + between " seconds at " and str(speed)
