Hello, I know this is a different topic, I am trying to complete the score in the Linux and Python test, I have finished all the tasks and everything works correctly, but the grading system said that my task1.py and task3.py are incorrect. I have completed the task1.py ( get_highest_lowest) in several ways, and it always work, I’ve even followed the recommendation you made in this topic to ignore the ‘inf’ value, it works correctly, but I still get the “incorrectly completed” on the grading. Can you help me checking this or maybe giving me some recommendation please.
Thanks in advance.
Hello @FreddyGarca,
Please send me your packages to aezquerro@theconstructsim.com so that I can check them.
I am having the same problem. Each task has been tested in the web-based terminal and works correctly according to the outputs in either the terminal or the simulation environment. However, it never passed any of the grading.
Any recommendations? Thanks!
Hello @stephen_dong_127,
Hi, I’m getting the same problem, I have been testing different ways to achieve the highest and the lowest positions but still getting wrong that part, on the simulations it works perfectly but when I upload the exam all I get is a wrong answer.
Some advice? Thank you.
Hello @leonardoquinonez98 ,
I’ve tried to search for your exam files in order to have a look at the code, but I couldn’t find them in your workspace. Where do you have them?
Hi @albertoezquerro , thank you for your support, I found the mistake yesterday and fixed the problem, looks like I wrote wrong a variable
Great!
Could you share here which was the issue (the variable you had wrong)? It can be helpful to other students that have a similar problem, or even for us in order to improve the instructions of the exam.
