Python3 for Robotics
2.6 Quiz
When you click on the right-arrow button (“Go to the next unit”) button on the bottom left-hand corner of the page, you should see the following window, or something like it, with a quiz appear:
If for some reason it does not show up, please let us know and we will fix the problem.
Hi, I can’t understand your post. Is this a question? Are you having trouble visualizing the quiz?
Yes, after some units, a quiz should appear to test what you’ve learned in that unit.
You can also manually trigger the quiz:
If the quiz (knowledge check) does not show up automatically, you can trigger it manually using the checkbox in the bottom-left (see image)
