Hi community
Could anyone help why there is a message that file services_quiz_client.launch.py was not found when it does exist as you can see on a screenshot?
Thank you
Hi @gvfstudio ,
A quick fix would be to delete the build
, install
and log
folders and rebuild your workspace just using the colcon build && source setup/install.bash
command.
cd ~/ros2_ws
rm -rf ./build ./install ./log
colcon build && source install/setup.bash
Sorry Girish I followed your advice but it didn’t work…
Hi @gvfstudio ,
Your setup.py
seems to be fine. I thought you might have missed something there.
I am not really sure of a solution. I have faced similar issues but when I do the delete and rebuild step, it gets fixed.
As an alternative you can try to run source /opt/ros/humble/setup.bash
before doing ros2 launch ...
“I am not really sure of a solution. I have faced similar issues but when I do the delete and rebuild step, it gets fixed”
It did work, thank you.
