I’m not sure what I got wrong, the software is marking:
[07:58:38] [assess] Not subscribed to /odom. Let’s get this sorted first.
Please check:
- Did you create a subscriber correctly to the topic
/odom in your source code?
- Did you use the right node name? It should be
topics_quiz_node (mark: 4.0)
What should I do?
system
Closed
2
The gradebot already pointed out the things that could be wrong. Did you check them?
