Hi
i am trying to get my head around the quiz scores, how do thy work?
sometimes i just get a mark 10, but i have no way of interpreting it, and how does it check and grade your quiz?
for instance:
quiz at exercise number 9
it does not specify what it would class as finish taking off, only that it needs to return an empty resault, does that mean that 2 meters is classed as being taken off, or 3 meters, also it is asking to publish 1hz feedback, but if you publish in /drone/land topic it takes less then 1seconds to land, so if i use that the algorithm is going to miss the feedback being published as it can happen to fast…
is there a more detail description where it sys how the quiz grading works, as i am now not sure should i check the solution’s, did i pass or did i fail? it only says quiz mark 10…
Ziga
