Good morning,
I am having the same issue with the gradebot, where gradebot repeatedly tells me the following:
Please check:
- Did you create a subscriber correctly to the topic
/odom in your source code?
- Did you use the right node name? It should be
topics_quiz_node
however, both issues are clearly resolved in the code and the robot ends up in the final position as requested.
Could you please look into the issue for me as I am running out of attempts.
Thanks,
Ghasef
The problem is that the /odom topic cannot be found when running your package:
ros2 topic info /odom -v
Unknown topic '/odom'
Please run the following commands and show us the output of both, after running the command in Terminal 2:
# Terminal 1
ros2 launch topics_quiz topics_quiz.launch.py
# Terminal 2
system
Closed
4
