Real robot connection not working
I booked a session for the real robot, everything worked perfect, but there seems to be a connection issue.
It looks like this:
Hi @stefanitro,
Thank you very much for reporting the problems with the cameras.
For some reason, the streaming computer was off, but it is now back again.
#KeepPushingYourROSLeaning
Hi @ralves ,
No problem, it happens.
The cameras are fine now, but still the robot control is not working, like in the picture below, nothing happens when trying to move it, tried it with teleop also.
Hope that it has a quick fix.
Best regards,
Stefan
Oh, the person who is in the lab is in a Live Streaming right now:
Let’s check this when the streaming finishes.
The robot is back running. It looks like the control board is crashing once a day. We are going to replace it next week. Until then, we will do a full reboot each day to prevent the issue.
Hi @rtellez ,
It’s great, thank you for solving it.
Best regards,
Stefan
Having the same problem even today
Hi @neilthomas110,
I just checked and the cameras are working, so, I suppose the problem was moving the robot, right?
We’ve double checked here, and everything seems to be working smoothly.
Could you be more specific on what exactly was not working, @neilthomas110?
If you can share any screenshot, that would help too.
We look forward to hearing from you.
Yes its all working perfectly now. I just had that issue a couple hours ago and fortunately everything is fine now.
I tried to connect today (right now) and getting the same no cameras issue.
There is the same connection issue again, with no robot camera, like in the screenshot.
Please help me with this.
Best regards,
Stefan
@IvanWoehr @stefanitro
I apologize, the power in the lab went down. Everything is back up now.
Hi @bayodesegun ,
Thank you for letting us know. Everything works great.
Best regards,
Stefan
Was able to test just fine now, thank you!!
