This week on Tuesday Evening and Wednesday early morning I used 2 slots to test on the real robot.
Unfortunately the camera was not loading then and the joypad was not working. I tried to connect multiple times but wasn’t able to get a good connection, so I couldn’t test anything.
I tried now to to another booking session, but got the message “that this week I used all my bookings”. Sorry I forgot, that there are only 2 bookings possible per week.
So I wanted to ask if it is possible to get 2 more bookings, since I could not really use them this week?
I don’t know what was the problem on Tuesday and Wednesday, if there were issues with the robot or my rosject. Bc 2 week ago the connection worked fine.
So I don’t know if there is maybe a possibility to see the status of the robot lab, to know if maybe there is currently an issue, so we don’t use bookings for nothing.
So I tried to connect again, but it is still not working.
You can see in the video that the stream is loading forever.
But the robot says it is connected.
I also tried to use 2 different internet connections (one WLAN and then with Hotspot from the mobile phone). Then I also tried with 2 different laptops. To see if anything of this causes the problem.
But it still doesn’t work.
I also tried to start the rviz to see if maybe the laser recording shows something, but also here nothing happens.
So could you please help me, so that I am able to get a good connection with the robot.
I don’t know what the issue could be.
It is very frustrating since basically of the around 8 times I tried to book the robot session, it only worked twice.
And since I can only book 2 times a week, I am not advancing at all with the project. So I don’t know how I will ever be able to finish the project, if I can not test with the robot.
Your assumption seems to be right. I tried on another PC and it worked. So like you said, it seems that something on the PC is blocking the connection with the camera. But I couldn’t figure out what exactly it might be.
Well anyway now that I finally found a way to test, would it be possible to again reset my bookings so I could get a few more trials for this week? That would be really great.
