Real Robot Lab is messy and the obstacles are on the path of the robot. The robot does not respond at all.
Hi @Adam_993, yes, the obstacles are usually moved around by everyone using the lab. We rearrange daily but it’s something that will happen from time to time.
As for the real robot, let me investigate. The robot resets for every session, so you should not have a problem if you book it again.
