Real Robot Lab - Turtlebot3 not moving problem
I am trying to use the Real Robot Lab with TurtleBot3. The web interface shows that I am connected with a latency of around 200ms, but moving the joystick does not make the robot respond. I thought it might be a session issue, so I ended the session and tried again, but it still does not work. When I checked with rosnode list and rosnode info /rosbridge_websocket, only rosbridge-related nodes are running, and there are no TurtleBot3 bringup nodes:
Node [/rosbridge_websocket]
Publications:
  • /client_count [std_msgs/Int32]
  • /cmd_vel [geometry_msgs/Twist]
  • /connected_clients [rosbridge_msgs/ConnectedClients]
  • /rosout [rosgraph_msgs/Log]
    Subscriptions:
  • /odom_status [unknown type]
  • /scan_status [unknown type]
  • /tf_status [unknown type]
    Services:
  • /rosbridge_websocket/get_loggers
  • /rosbridge_websocket/set_logger_level
I would also like to ask a couple of questions:
  • Does the Real Robot Lab operate on weekends (Saturday/Sunday)?
  • I am planning to use the TurtleBot3 during weekday evenings. Is it available at all times on weekdays, regardless of the time?
Thank you very much for your assistance.
@daylight1234567
The robot should be working now; please try again.
We are working on intermittent freezes with this robot, which started recently. Kindly bear with us.
The robot is available 24/7.
The issue looks to insist. I have been trying since yesterday to make the robot move (It is connected).
The available topics are:
ros2 topic list
/camera_info
/client_count
/cmd_vel
/connected_clients
/image_raw
/image_raw/compressed
/image_raw/compressedDepth
/image_raw/theora
/imu
/joint_states
/odom
/odom_status
/parameter_events
/rosout
/scan
/scan_status
/tf
/tf_static
/tf_status
but the echo command doesn’t return anything to many of those topics…
Thank you very much for your work. Looking forward to make it move for the first time!
I’m sorry about that. Could you please try again? The robot probably froze again.
