Real robot lab very slow
Hi, I tried for the first time turtlebot real robot lab the robot get commands for line 2/3 seconds, then stop, if i relaunch my node, the robot restart, move for 2/3 seconds, then suddendly stop…
The same code work without problema in simulation…
Thanks,
Igor
Hi, welcome to the community!
Did the same issue happen when you moved it around with the joystick?
The robot has a velocity limit for safety, so that might explain the stopping. Try using a linear velocity lower than 0.15.
When I use the joystick the movement is continuous, when I use my node the robot advance for a few centimeters, stop, wait, then restart. The robot follows the programmed path, but with a stop and go pace…
this is my node code (it’s ros2, but I launch ros1 bridge…):
import rclpy
from rclpy.node import Node
class WallController(Node):
    x = 0
    z = 0
        super().__init__('WallController')
        self.publisher_cmd_vel = self.create_publisher(Twist, 'cmd_vel', 10)
        self.subscriber_scan = self.create_subscription(LaserScan, 'scan', self.scan_callback, 10)
    def move(self,x,z):
        msg = Twist()
        self.x = x
        self.z = z
        msg.linear.x = self.x
        msg.angular.z = self.z
        self.publisher_cmd_vel.publish(msg)
    def scan_callback(self, msg):
        steps = (msg.angle_max - msg.angle_min)/msg.angle_increment
        right_step = int(steps / 4.0 * 1.0)
        front_step = int(steps / 2.0)
        self.get_logger().info('STEPS: %f,%f %f' % (steps, front_step, front_step))
        right_wall_distance = msg.ranges[right_step]
        front_wall_distance = msg.ranges[front_step]
        if front_wall_distance < 0.6:
            self.move(0.0, 0.48)
        else:
            if right_wall_distance < 0.5:
                self.move(0.10, 0.15)
            elif right_wall_distance >= 0.5 and right_wall_distance < 0.6:
                self.move(0.14, 0.0)
            else:
                self.move(0.10, -0.15)
        self.get_logger().info('%f,%f %f:%f' % (front_wall_distance, right_wall_distance, self.x, self.z))
def main(args=None):
    rclpy.init(args=args)
    wall_controller = WallController()
    rclpy.spin(wall_controller)
    wall_controller.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
Have you tried spinning your node at a faster rate? Maybe the publishing needs to be faster.
Here is some info that can be useful:
https://answers.ros.org/question/358343/rate-and-sleep-function-in-rclpy-library-for-ros2/
