I am unable to connect to the real robot, everytime I try to - it shows me this error
The robot appears to be offline right now. Kindly request the manager to reconnect it using “sudo systemctl restart theconstruct.rrl” and try again. Checking the robot’s logs with “sudo journalctl -f -u theconstruct.rrl” and “sudo husarnet status” also may help.
I tried running those commands in the terminal but it says again that it can’t connect. I really need help fixing this because I have my presentation tomorrow and wanted to test my robot!
Hi Nahl,
we have reset the robot right now. But it looks like there is a deeper problem, since the robot has been giving problems in the last week even when rebooted.
You can use it now, but today we are going to take a serious look to prevent this from happening again
I have just run with it now and during my tests the laserscan stopped working. I was not able to get it working again so now it is useless. The joystick continued working, so the robot was not completely dead.
Thanks for the feedback.
Yesterday we did a full remodeling of the power cabling system, which was causing part of the problems. The laser should be working properly now.
