I am working in the Path Planning section of the rosject, however I am having difficulties in setting the path_planner and controller parameters. The robot does not move smothly when I send a goal, sometimes it moves, then stops and it does not reach the goal.
An example of an error that I got is the following:
controller_server-2] [ERROR] [1680286255.233165771] [tf_help]: Transform data too old when converting from odom to map
[controller_server-2] [ERROR] [1680286255.233208610] [tf_help]: Data time: 588s 366000000ns, Transform time: 588s 66000000ns
[controller_server-2] [ERROR] [1680286255.233353927] [controller_server]: Unable to transform robot pose into global plan's frame
[controller_server-2] [WARN] [1680286255.233455596] [controller_server_rclcpp_node]: [follow_path] [ActionServer] Aborting handle.
As you can see from the images, the robot stopped without reaching its goal.
The parameters that I have changed are:
- Robot diameter for global and local cost map.
- Controller frequency
- max_vel_x
- max_vel_theta
path_planner.yaml
planner_server:
ros__parameters:
expected_planner_frequency: 8.0
use_sim_time: True
planner_plugins: ["GridBased"]
GridBased:
plugin: "nav2_navfn_planner/NavfnPlanner"
tolerance: 0.5
use_astar: true
allow_unknown: true
global_costmap:
global_costmap:
ros__parameters:
update_frequency: 1.0
publish_frequency: 1.0
global_frame: map
robot_base_frame: base_link
use_sim_time: True
robot_radius: 0.12
resolution: 0.05
track_unknown_space: true
plugins: ["static_layer", "obstacle_layer", "inflation_layer"]
static_layer:
plugin: "nav2_costmap_2d::StaticLayer"
map_subscribe_transient_local: True
inflation_layer:
plugin: "nav2_costmap_2d::InflationLayer"
cost_scaling_factor: 2.0
inflation_radius: 0.1
always_send_full_costmap: True
obstacle_layer:
plugin: "nav2_costmap_2d::ObstacleLayer"
enabled: True
observation_sources: scan
scan:
topic: /scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
controller.yaml
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 8.0
min_y_velocity_threshold: 0.5
failure_tolerance: 0.3
progress_checker_plugin: "progress_checker"
goal_checker_plugins: ["general_goal_checker"]
controller_plugins: ["FollowPath"]
# Progress checker parameters
progress_checker:
required_movement_radius: 0.5
movement_time_allowance: 10.0
# Goal checker parameters
general_goal_checker:
stateful: True
xy_goal_tolerance: 0.25
yaw_goal_tolerance: 0.25
# DWB parameters
FollowPath:
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.20
max_vel_y: 0.0
max_vel_theta: 0.52
min_speed_xy: 0.0
max_speed_xy: 0.2
min_speed_theta: 0.0
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
trans_stopped_velocity: 0.25
stateful: True
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
GoalAlign.scale: 24.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: odom
use_sim_time: True
rolling_window: true
width: 1
height: 1
resolution: 0.05
robot_radius: 0.12
plugins: ["voxel_layer", "inflation_layer"]
inflation_layer:
cost_scaling_factor: 1.8
voxel_layer:
plugin: "nav2_costmap_2d::VoxelLayer"
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
scan:
topic: /scan
clearing: True
marking: True
static_layer:
I will appreciate any kind of help.
Thanks
Best Regards,
Ronaldo
