Reopening quiz solution
I noticed that alot of people had the same problem as me. I finished the quiz of unit 3 and got a 10/10 grade, then wanted to see how the instructor solved the problem (since the solution will have a more efficient code) but was not able to see it in time. The Construct instructors, please let us see your code more than once.
Thank you
Hello!
Our records indicate that you have seen the solution of this quiz. What do you mean by “was not able to see it in time”? What really happened?
Thank you for your response bayodesegun, I meant that my connection timed out before I finished reviewing the code. I understand that it was done that way to prevent cheating but it would be useful to check the code more than once after getting a full grade on the test.
