Request: Can I submit the quiz after viewing the solution?
Hi team, I submitted five times for auto-grading the quiz. It warned me that I wouldn't be able to submit the quiz again but I thought it was for the auto-grading and I proceeded to check the solution thinking that I was checking my own solution that I was going to submit. My code which I was about to check using auto-grader was working perfectly while doing simulation as I did review and update the code. Now I can't submit my latest and reviewed code which works well. Help me to submit it. I haven't looked at the solution that was generated. I did not copy nor give a glance to the solution which I did not expect. Please help me to submit my final solution which I have proudly done myself. Hoping for the best. The team can even crosscheck and compare my solution with the company solution. Hoping for the best.
Thank you.
Thank you for reaching out about this. Unfortunately, you can no longer submit for grading after viewing the solution. Furthermore, you have exhausted all your five attempts.
That said, if you are planning to get the certificate for this course, you will need to complete the Real Robot Project presentation. If you do well in that project, I will allow you to retake this quiz. When you pass the presentation, just point me or any member of the team to this post.
By the way, you already did well in the quiz, scoring 8 out of 10. Good job!
I would like to clarify whether my current quiz grade has any impact on my overall course progress and certification. Additionally, I am interested in retaking the course after completing it to reinforce my learning. Could you please provide guidance on the process for re-enrollment?
I truly appreciate your support and consideration. Looking forward to your response.
No, it does not. The quiz counts towards your % completion for the course, not the certification. For this course, the certificate is 100% based on your performance in the Real Robot Project and its presentation.
We don’t have a formal process for that now. Just go back to the first unit. When you are ready, contact us here and we’ll reset your progress.
We might have a “reset” button for that in the future.
