Resetting final exam work so that I can reattempt the exam
Hi.
Can you reset my records so that I can attempt the ROS for Beginners final exam again?
I was not able to correct Task3 and due to that got a low score and hence want to reattempt the exam and try to solve again.
Let me know kindly
@sambaranghosal
You can retry the exam as many times as you want as long as you don’t click the View Solution link.
Hi … Accidently I had pressed the View Solution button instead of the close button by mistake. But since the solution is not published, I would like to again retry. But since I clicked the solution button I cannot resubmit. IS there any way that this can be bypassed because I really want to see how my work is against the standards?
Kindly do something and let me know…
Thanks a lot
Hi @sambaranghosal,
We don’t accept a reason like “accidentally pressing the View Solution button” because there is a bold note there specifying the implications, but since there is no solution file anyways I have cleared the “viewed solution” bit and you can now retry the exam.
