Is there currently away to restart a course from scratch? Sometimes I want a clean slate from which I can build again but better. If not, this would be a fantastic tool. Thank you!
Manuel
Manuel
The easiest (but dangerous) way to do this is to simply delete your workspace’s compilation folders, and everything inside /src. Basically, everything inside your ros2_ws.
You will lose everything inside though, so be careful.
