I completed my action quiz but there were some correction in my program when I submitted it so I wanted to check solution…so when I clicked on check solution nothing appeared and my quiz got submitted and now I want to resubmit it so that I will come to know whether my program is correct or not but now the grader shows that I will not be able to resubmit it because I have seen the solution even though I have not.Please do something about this issue.
Hi @Soham_SD ,
Unfortunately it is designed like that. You must do it completely on your own to get an accepted grade for the certificate, without seeing solution.
Jialei Li
but the solution was not shown it directly got submitted
