My codes for the final exam were right and accurate but I really don’t think I deserve a grade ‘5’ for my codes. Kindly look into the grading.
Thank you for letting us know. Please allow us some time to look into this and get back to you.
Sir, any update regarding my marks
“Drone didn’t do motion” is incorrect as it certainly moves.
Also “Drone did not move enough” is not acceptable because the drone is commanded with a given velocity and the time period is fixed, which makes the distance covered fixed. Can I expect my problem to be solved at least now
Thank you for your follow up. I apologize for the delay, but we have been in the middle of some intensive work and have not been able to have a look at your solution.
Please give us some more time. We will surely have a look at your solution and the autocorrection script and ensure you get the result you really deserve.
Many thanks for your patience.
