RLException: [main.launch] is neither a launch file in package
I’m getting this error when running the following command
“roslaunch duckietown_gazebo main.launch”
And the error is
“RLException: [main.launch] is neither a launch file in package [duckietown_gazebo] nor is
[duckietown_gazebo] a launch file name
The traceback for the exception was written to the log file”
I try to run live lecture #30 locally,
I download the files I need, ran “catkin_make” (it went fine), then “source devel/setup.bash” and then “rospack profile”. Then I try to run the launch file, which fails.
  • I’m able to run “roslaunch fake_navigation start.launch” but firstly, nothing happens (no simulation or anything). Secondly, this is not the file that was used in the live class.
  • I downloaded the fake_navigation folder (as is) from that live demo and placed it inside catkin_ws. Also downloaded the simulation directory (simulation_ws) and put it outside of catkin_ws (they’re at the same level)
Any help to run it locally will be highly appreciated(!)
So most of our course simulations are public, you can find them in our git.
Here is the one used in the course: https://bitbucket.org/theconstructcore/riabot/src/master/
Just download it and solve any dependecies you might have locally and launch:
roslaunch duckietown_gazebo city.launch
Hope it helped
