Robot does not show up on gazebo
I am going through the first robot course and I have got to the point where you can should see the robot in gazebo. I cannot see it. I can see it rviz though. I haven’t modified anything - I was following the course and when it all works, I will modify.
Here is the message :
slight_smile: user:~$ roslaunch rosbots_description spawn.launch
… logging to /home/user/.ros/log/f5e457b2-9a52-11eb-810c-0242ac150008/roslaunch-7_xterm-1369.log
Press Ctrl-C to interrupt
started roslaunch server http://7_xterm:38125/
SUMMARY
PARAMETERS
    • /robot_description: <?xml version="1…*
    • /rosdistro: kinetic*
    • /rosversion: 1.12.14*
NODES
  • mybot_spawn (gazebo_ros/spawn_model)*
ROS_MASTER_URI=http://7_simulation:11311
process[mybot_spawn-1]: started with pid [1388]
SpawnModel script started
[INFO] [1618096738.862834, 0.000000]: Loading model XML from ros parameter
[INFO] [1618096738.869275, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1618096738.872317, 67.139000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1618096739.077948, 67.225000]: Spawn status: SpawnModel: Successfully spawned entity
[mybot_spawn-1] process has finished cleanly
log file: /home/user/.ros/log/f5e457b2-9a52-11eb-810c-0242ac150008/mybot_spawn-1.log*
done
user:~$
If I go into graphical tools I see nothing.
What stupidity have I done ?
Hi, welcome to the community! Are you getting errors inside the course or a rosject? You shouldn’t have to launch simulations in the course, they are available for you when you open them. If you are in a course, which unit is it?
If there are no errors in the simulation, maybe it’s a visualization issue, so try to see if by moving the camera around and see something. If not, try restarting your rosject. But again, I don’t know if you are doing this in the course or a rosject.
