I’m trying to connect to the real robot and I’m getting the following message
The robot appears to be offline right now. Kindly request the manager to reconnect it using “sudo systemctl restart theconstruct.rrl” and try again. Checking the robot’s logs with “sudo journalctl -f -u theconstruct.rrl” and “sudo husarnet status” also may help.
Hi, which robot were you trying to connect to?
If you meant the TurtleBot3 Lab, you should be able to connect now.
