Hello
Is there a tool to automatically generate a ROS 2 security policy package for a custom robot setup? using gazebo harmonic (not gazebo classic)
https://bitbucket.org/theconstructcore/turtlebot3_security_policy/src/master/
Hello @MohamedAliZouari ,
You should be able to use the ros2 security generate_policy command for generating a custom policy. This command will take the ROS graph at the point of running and generate the policy.xml file that corresponds to it.
Hope this helps,
