Hi, could you help me to restart my IDE of ROS in 5 Days C++? I did wrong things and now i don’t know what happens
I had the same thing in the python course . If you open another course and come back to the same course again the IDE will restart ,but everything you did will restart also for that unit.
Enter and no change was generated. I tried to delete everything to see if it restarted completely but nothing, now it’s empty.
Can you see your files via the terminals? If so, you just need to re-jig the IDE.
Click on the Files icon in the IDE and then click on the again to restart the explorer.
If that does not work, click the reload button at the bottom-right to reload the IDE.
