Hi, I am going through the ROS Services module in the above course. I get this error on launch:
ERROR: cannot launch node of type [service_client_pkg/service_client_pkg_node]: Cannot locate node of type [service_client_pkg_node] in package [service_client_pkg]. Make sure file exists in package path and permission is set to executable (chmod +x)
The file exists and has the correct permissions. I don’t really know why I’m getting this error message, and what to do about it. Any help would be appreciated.
Launch file:
<launch>
<include file="$(find trajectory_by_name)/launch/start_service.launch"/>
<node pkg="service_client_pkg"
type="service_client_pkg_node"
name="service_client"
output="screen">
</node>
</launch>
Cpp file: service_client_pkg_node.cpp
#include "ros/ros.h"
#include "trajectory_by_name_srv/ls.h"
// Import the service message used by the service /trajectory_by_name
ros::init(
argc, argv,
"service_client"); // Initialise a ROS node with the name service_client
ros::NodeHandle nh;
// Create the connection to the service /trajectory_by_name
ros::ServiceClient traj_by_name_service =
nh.serviceClient<trajectory_by_name_srv::TrajByName>(
"/trajectory_by_name");
trajectory_by_name_srv::TrajByName srv; // Create an object of type TrajByName
srv.request.traj_name =
"release_food"; // Fill the variable traj_name with the desired value
if (traj_by_name_service.call(srv)) // Send through the connection the name of
// the trajectory to execute
ROS_INFO("%s",
srv.response.status_message
.c_str()); // Print the result given by the service called
} else {
ROS_ERROR("Failed to call service /trajectory_by_name");
return 1;
return 0;
CMakeLists.txt file:
project(service_client_pkg)
roscpp
message_generation
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
add_service_files(
FILES
TrajByName
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
# std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES service_client_pkg
CATKIN_DEPENDS roscpp trajectory_by_name_srv message_runtime
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/service_client_pkg.cpp
## Declare a C++ executable
add_executable(${PROJECT_NAME}_node src/service_client_pkg_node.cpp)
add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_node_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(${PROJECT_NAME}_node
${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_service_client_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
