For Exercise 3.1, when I execute the file, I get the following output:
... logging to /home/user/.ros/log/804b3f80-cf9e-11eb-845e-0242c0a82008/roslaunch-1_xterm-18776.log
Press Ctrl-C to interrupt
started roslaunch server http://1_xterm:32941/
SUMMARY
PARAMETERS
* /rosdistro: noetic
* /rosversion: 1.15.9
NODES
iri_wam_reproduce_trajectory (iri_wam_reproduce_trajectory/iri_wam_reproduce_trajectory_node)
service_client (service_client_pkg/simple_service_client)
traj_by_name_node (trajectory_by_name/traj_by_name.py)
process[iri_wam_reproduce_trajectory-1]: started with pid [18784]
process[traj_by_name_node-2]: started with pid [18785]
process[service_client-3]: started with pid [18786]
[ INFO] [1623961563.284887830]: Waiting for action server to start.
[ INFO] [1623961563.292194414]: Ready execute trajectories
[ INFO] [1623961563.298330172]: Running
[ERROR] [1623961563.299507396]: Failed to call service /trajectory_by_name
[service_client-3] process has died [pid 18786, exit code 1, cmd /home/user/catkin_ws/devel/lib/service_client_pkg/simple_service_client __name:=service_client __log:=/home/user/.ros/log/804b3f80-cf9e-11eb-845e-0242c0a82008/service_client-3.log].
log file: /home/user/.ros/log/804b3f80-cf9e-11eb-845e-0242c0a82008/service_client-3*.log
______________________________________________________________________
Here is my launch file:
<launch>
<include file="$(find trajectory_by_name)/launch/start_service.launch"/>
<node pkg ="service_client_pkg"
type="simple_service_client"
name="service_client"
output="screen">
</node>
</launch>
Here is my CMakeLists.txt file (the extra #'s are to keep the forum editor from weirdly formatting the text):
project(my_package)
roscpp
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES my_package
# CATKIN_DEPENDS roscpp
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_package.cpp
## Declare a C++ executable
add_executable(simple src/simple.cpp)
add_dependencies(simple ${simple_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple
${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_package.cpp)
# endif()
# catkin_add_nosetests(test)
I think it has something to do with launching the service, because if I launch it manually, it works.
Hi, like the error says, it’s having an error when trying to launch the trajectory_by_name
service, and your CMakeLists.txt
doesn’t have the add_service_files(
section commented out. This might be casing the problem. Also, maybe it’s the formatting of your launch file? I see that the include tag is in front of the node tag.
The include tag before the node tag is the format used in the tutorial. The tutorial also does not say anything about editing the CMakeLists.txt file in relation to add_service_files(. I would think that an issue with CMakeLists.txt would cause the error even if I launch the service manually in the terminal, but if I do that, it works fine.
If it works with rosrun
, then maybe your launch file is missing something. What’s inside start_service.launch
? it looks like the node in charge of advertising the service /trajectory_by_name
is maybe not getting launched?
Thanks for the reply. At the bottom is my launch file. I’m wonder if there’s something wrong with the way I’m starting /trajectory_by_name. If I start the service using
roslaunch trajectory_by_name start_service.launch
in a different shell, then I launch traj_by_name.launch, then I get the same error message, but it works. Here’s the output that I get:
process[service_client-3]: started with pid [4968]
[ INFO] [1624372861.703965658]: Waiting for action server to start.
[ INFO] [1624372861.719344657]: Ready execute trajectories
[ERROR] [1624372862.339523019, 1351.325000000]: Failed to call service /trajectory_by_name
[ INFO] [1624372862.384915906, 1351.370000000]: Action server started, sending goal.
[service_client-3] process has died [pid 4968, exit code 1, cmd /home/user/catkin_ws/devel/lib/services_31/traj_by_name __name:=service_client __log:=/home/user/.ros/log/a809c7fc-d364-11eb-a106-0242c0a80008/service_client-3.log].
log file: /home/user/.ros/log/a809c7fc-d364-11eb-a106-0242c0a80008/service_client-3*.log
[ INFO] [1624372871.834794499, 1360.683000000]: Action finished: SUCCEEDED
If I don’t launch the service in a separate shell, then I get the error message, but it doesn’t run:
[ INFO] [1624372841.067351261]: Waiting for action server to start.
[ INFO] [1624372841.078982146]: Ready execute trajectories
[ERROR] [1624372841.092868362]: Failed to call service /trajectory_by_name
[service_client-3] process has died [pid 4877, exit code 1, cmd /home/user/catkin_ws/devel/lib/services_31/traj_by_name __name:=service_client __log:=/home/user/.ros/log/a809c7fc-d364-11eb-a106-0242c0a80008/service_client-3.log].
Here’s the launch file I’m using:
Launch File:
<launch>
output="screen">
</node>
</launch>
Maybe you are launching more than one service servers, and that causes the nodes to kill each other. Try removing the start_service.launch from your launch file or killing everything else on your terminals
If I start the service in a different shell, then it works. If I don’t - if I kill everything else - then it doesn’t work.
Maybe you need to wait for the service in your code? Have a look at this post:
Thanks for the help! That fixed the problem. Since the c++ code is provided for this exercise, it seems like
ros::service::waitForService("/trajectory_by_name");
should be included in the provided code.
