This error occurs after doing the catkin build call.
even tried with catkin make but the same happens.
“Traceback (most recent call last):
File “/usr/bin/catkin”, line 6, in
from pkg_resources import load_entry_point
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 3243, in
def _initialize_master_working_set():
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 3226, in _call_aside
f(*args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 3255, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 568, in _build_master
ws.require(requires)
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 886, in require
needed = self.resolve(parse_requirements(requirements))
File “/usr/local/lib/python3.8/dist-packages/pkg_resources/init.py”, line 772, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The ‘osrf-pycommon>0.1.1’ distribution was not found and is required by catkin-tools”
