ROS Basics in 5 Days (Python) Exam
For the final exam (drone challenge), it is mentioned that there is a time limit of two hours. Where can I see the timer to know how much time I have left to complete the exam and when does the timer start?
Hi @aryakurian ,
If I am right, I believe you are confusing the “time required for completing this unit” with “time left for finishing this unit”.
If the course notebook says that “time required” is 2 hours, then it technically take you two hours to finish this unit.
If you do not see a countdown timer for 2 hours, then there is no timer implemented in the unit. It is just an information to help you manage time and let you know to not spend more than 2 hours on completing the unit.
I hope this helps.
Alright, thank you for clarifying.
