ROS Basics in 5 days (python) Final Exam Drone Challenge
Hope you’re doing great
I have problem in the final exam Drone Challenge
Task1a,
Same code as below
#!/usr/bin/env python
rospy.init_node(‘drone_takeoff_node’, anonymous=True)
pub = rospy.Publisher(‘/takeoff’, Empty, queue_size=1)
rospy.loginfo(“Publishing Ready…”)
rospy.sleep(5)
rospy.loginfo(“Taking Off…”)
pub_msg = Empty()
pub.publish(pub_msg)
rospy.spin()
one time the autocorrecter bot check it as correct other time as wrong
what should i do ??
Big Thanks in advance
Regards
Abdel Raouf DANNAOUI
It looks like your drone is not taking off consistently, perhaps because your messages are getting lost. Instead of using rospy.sleep(5), see:
