rosservice call /my_service [TAB]+[TAB]
File “”, line 1
SyntaxError: invalid syntax
File “”, line 1
Hi @shrirangsp,
Welcome to the commuity
This is not meant to be executed directly. You are supposed to type:
in the Terminal and then press [TAB] on your keyboard twice to autofill the rest of the command.
Thank you @simon.steinmann91
I has pressed [TAB] button twice and I got that error.
can you post a screenshot?
I cannot see /my_service anymore
But /move_bb8_in_circle that i tried worked perfectly.
Make sure that your service server is running.
Please read the instructions care fully , it works as shared in Example 5.4 section .
For Demo use below 2 commands only
Shell#1 : roslaunch trajectory_by_name start_service.launch
Shell#2 rosservice call /trajectory_by_name “traj_name: ‘get_food’”
Output on the shell will be like this
success: True
status_message: “Successfully executed trajectory”
Robot Arm should also move
