For completing exercise 3.1 should i code according to the course instruction or rosjet instruction and after completing the simulation work in rosjet how should i proceed further in the course
Hi @sumedh, the rosject is the project side of the ROS Basics course. So, you should separate them in your mind. If exercise 3.1 is in the course, then adhere to the course instructions.
Once you complete the simulation work, you should book the turtlebot3 robot here to test your code on the real robot.
Once you complete the project on the real robot, you can schedule a presentation (by emailing info@theconstructsim.com) in order to get a certificate of learning.
