Hello all,
I am currently in the 3.1 Topic Publisher exercise, and believe I am stuck in the creating launch file portion.
I find it rather annoying there not being any instruction or answer to how to solve it within the exercise itself. Hopefully someone on here can help me please. My current launch file contains this code
<launch>
<!-- My Package launch file -->
<node pkg="topic_publisher_pkg" type="simple" name="ObiWan" output="screen">
</node>
</launch>
Thanks in advance as always.
This is my current directories and where everything is.
And this is the error I come upon when using roslaunch.
You’re not stuck at the point of creating a launch file. The problem is that your executable has not been properly compiled. Please go over the steps again, carefully:
- Did you modify
CMakeLists.txt properly?
- Did you run
catkin_make and source devel/setup.bash successfully?
Thanks for the response. I belive CMakeLists.txt should be fine. The below is my CMakeLists.txt & the edit I have within.
And I have also ran both catkin_make & source devel/setup.bash successfully.
But still arrive at the same issue unfortunately
project(topic_publisher_pkg)
roscpp
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES topic_publisher_pkg
# CATKIN_DEPENDS roscpp std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/topic_publisher_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/topic_publisher_pkg_node.cpp)
# ${catkin_LIBRARIES}
add_executable(simple src/simple.cpp)
add_dependencies(simple ${simple_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple
${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_topic_publisher_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
add_executable(simple_topic_publisher src/simple_topic_publisher.cpp)
add_dependencies(simple_topic_publisher ${simple_topic_publisher_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple_topic_publisher
${catkin_LIBRARIES}
Hello Bayodesegun,
I searched a previous forum post on this exact question you have solved.
It seems to be this part that solved the entire issue.
Removing build & devel to recompile allowed the node to be recognized somehow. Thank you.
# run from catkin_ws directory
rm -rf build/ devel/
cakin_make
source devel/setup.bash```
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
