Once inside, Click on ctrl+A to select all, ctrl+C to copy
Now navigate to the reply section on the forum, press on the button at the top bar with the symbol </> and paste the content you copied. This button conserves the formating, indents etc.
package name my_package in …/package.xml does not match current PROJECT_NAME my_package_test.
Either
you created the package by copying another package - if this, then better create the package from scratch using catkin_create_pkg - or
you edited your package.xml and/or CMakeLists.txt wrongly. In this case, please go through these files and make sure the package name is the same in every place where the package name is mentioned.
@Bulat4 what is the issue? Have you followed what @bayodesegun has told you? The error corresponds to what he is saying. You need to correct your package.xml and CMakeLists.txt to fix those compilation errors.
project(my_package_test)
roscpp
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES my_package_test
# CATKIN_DEPENDS roscpp
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_package_test.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_package_test_node.cpp)
# ${catkin_LIBRARIES}
add_executable(simple src/simple.cpp)
add_dependencies(simple ${simple_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple
${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_package_test.cpp)
# endif()
# catkin_add_nosetests(test)
type or paste code here
I have done some modifications and am at this stage now.
Majority of the codes are executing but the bottom portion still shows up as error
This was the intended output
type or paste code hereuser catkin_ws $ roslaunch my_package my_package_launch_file.launch
... logging to /home/user/.ros/log/d29014ac-911c-11e6-b306-02f9ff83faab/roslaunch-ip-172-31-30-5-28204.log
Press Ctrl-C to interrupt
started roslaunch server http://ip-172-31-30-5:40504/
SUMMARY
PARAMETERS
* /rosdistro: indigo
* /rosversion: 1.11.20
NODES
ObiWan (my_package/simple)
ROS_MASTER_URI=http://localhost:11311
core service [/rosout] found
process[ObiWan-1]: started with pid [28228]
[ INFO] [1515028076.948011193]: Help me Obi-Wan Kenobi, you're my only hope
[ObiWan-1] process has finished cleanly
log file: /home/user/.ros/log/d29014ac-911c-11e6-b306-02f9ff83faab/ObiWan-1*.log
done
This means you haven’t included the node simple correctly in my_package. This can be because it is not added as an executable. Make sure the name you add in CMakelists for your executable is the same, and don’t forget to compile and source again
I have found it rather complicated to fix lines within each file and instead chose to start over. I have completed that unit and believe my mistake stemmed from mainly forgetting to compile packages before using roslaunch.
