Hello. I am trying to run my ROS project on a real robot. It works perfectly fine in the simulation. When I start the real robot, it runs for a few seconds, and then the ros bridge terminates due to user request (I did not request it). The problem happens when FSM is in state S3.
[ WARN] [1688656949.763434363]: Shutdown request received.
[ WARN] [1688656949.974102462]: Reason given for shutdown: [user request]
I do not understand whether the problem is in my code or on the server. What can I do about it?
My code is:
import rclpy
# import the ROS2 python libraries
from rclpy.node import Node
# import the Twist module from geometry_msgs interface
# import the LaserScan module from sensor_msgs interface
import time
class Wall_following(Node):
# Here you have the class constructor
# call the class constructor
super().__init__('wall_following')
# create the publisher object
# create the subscriber object
self.subscriber = self.create_subscription(LaserScan, '/scan', self.laser_callback, QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE))
# define the timer period for 0.5 seconds
self.timer_period = 0.5
# define the variable to save the received info
self.laser_data = []
# create a Twist message
self.cmd = Twist()
self.timer = self.create_timer(self.timer_period, self.motion)
self.state = "S0"
self.linear_velocity_value = 0.3
self.rotational_velocity_value = 0.3
self.linear_velocity = 0
self.rotational_velocity = 0
def laser_callback(self,msg):
# Save the frontal laser scan info at 0°
self.laser_data = msg.ranges
def motion(self):
while(self.laser_data == []):
time.sleep(0.1)
self.get_logger().info("Waiting for laser data")
laser_forward = self.laser_data[350]
laser_right = self.laser_data[270]
# print the data
self.get_logger().info("Forward distance: " + str(laser_forward) + " Right distance: " + str(laser_right))
if(laser_forward < 0.5):
self.state = "S3"
elif(laser_right > 0.3):
self.state = "S2"
elif(laser_right < 0.2):
self.state = "S1"
else:
self.state = "S0"
if self.state == "S0":
self.state_S0()
elif self.state == "S1":
self.state_S1()
elif self.state == "S2":
self.state_S2()
elif self.state == "S3":
self.state_S3()
else:
self.get_logger().info("FSM is broken")
self.cmd.linear.x = self.linear_velocity
self.cmd.angular.z = self.rotational_velocity
# Publishing the cmd_vel values to a Topic
#S0- go straight
def state_S0(self):
self.linear_velocity = self.linear_velocity_value
self.rotational_velocity = 0.0
self.get_logger().info("S0")
#S1- slight left turn
def state_S1(self):
self.rotational_velocity = self.rotational_velocity_value
self.get_logger().info("S1")
#S2- slight right turn
def state_S2(self):
self.rotational_velocity = -self.rotational_velocity_value
self.get_logger().info("S2")
#S3- sharp left turn
def state_S3(self):
self.linear_velocity = 0.0
self.get_logger().info("S3")
def main(args=None):
rclpy.init(args=args)
wall_following = Wall_following()
rclpy.spin(wall_following)
# Explicity destroy the node
wall_following.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
