ROS Developers Extra Class n2
Where is the roject located that i can fork that u use in this class? I cant find it.
Hi @badmadafaka ,
I just found the live class, it is listed in the Live Classes page
https://app.theconstructsim.com/#/LiveClass/56be7145-2dd7-457d-a60e-e337aa889e45
Let me know if that works for you!
Regards
thanks, the i cannot fork the projekt tho:
Hi @badmadafaka ,
I just fix the correct link to this rosject, you should be able to fork and run it now
Please let me know if not
Regards
Thank you, I can fork it and everything now. However, I cant get the simulation to run. I think there is a bug. Are you willing to try, to see if it works for u?
Best regards
Hi @badmadafaka ,
I tried to recompile the packages with the following commands
source ~/home/simulations/public_sim_ws/devel/setup.bash
cd ~/simulation_ws/
catkin_make
source ~/simulation_ws/devel/setup.bash
cd ~/catkin_ws/
catkin_make
It may be necessary if the workspaces had some inconsistency in its compiled files.
Finally, I tried to launch the simulation but I still get another error.
We are working on it to figure out the issue.
Thank you for your patience, sometimes after updates in the platform, we need to adjust some of these old rosjects.
I’ll get back with a proper answer as soon as I have it
Regards
Thank you, how long do you think it will take? Because I need it for an assignment, and if its not a quick fix, i will make it somewhere else.
Best
Can I get an update?
Hi @badmadafaka ,
Thanks for your patience. Unfortunately we still don’t have a solution, our team is working on it.
