ROS_DISTRO was set to 'galactic' before
While working on Unit 2 of Advanced Navigation, I encountered multiple issues related to environment setup and launching navigation components.
Sourcing setup.bash results in environment conflict:
ROS_DISTRO was set to 'galactic' before. Please make sure that the environment does not mix paths from different distributions.
ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions.
This suggests a conflict between ROS1 (Noetic) and ROS2 (Galactic) environment variables.
Launching navigation.launch fails:
[ERROR] [map_server-1]: process has died [pid 1447, exit code 127, cmd '/opt/ros/galactic/lib/nav2_map_server/map_server --ros-args -r__node:=map_server --params-file /tmp/launch_params_gu9tv2xa --params-file /tmp/launch_params_kdiu83qx'].
Running teleop_twist_keyboard results in message type error:
File "/opt/ros/galactic/lib/teleop_twist_keyboard/teleop_twist_keyboard", line 11, in <module>
  load_entry_point('teleop-twist-keyboard==2.3.2', 'console_scripts', 'teleop_twist_keyboard')()
AttributeError: type object 'type' has no attribute '_TYPE_SUPPORT' This might be a ROS 1 message type but it should be a ROS 2 message type. Make sure to source your ROS 2 workspace after your ROS 1 workspace.
This might be due to an improper sourcing order between ROS1 and ROS2 workspaces.
This specific warning is common and usually harmless. It is unlikely that this is the actual problem. Perhaps you are running the wrong command?
To help further,
  • please ensure you did not skip any part of the notebook (from the top)
  • let us know the specific point in the notebook where you ran into this error
  • please share a full screenshot showing the error on the terminal, and the exact command you ran
