After that I submitted my quiz I clicked to check the solution but nothing happened. Now, I do not know where to go to check the solution. Could you please help me?
Thanks.
J
Thanks.
J
Hello @potto95 ,
Your option to check the solution is still available. You will be able to click on it after sending your Quiz for revision.
Once you click on the Check Solution button, a new notebook will open up with the solution. I’ve just tested the process and it’s working OK. If any error occurs, please let us know and take a screenshot (if possible) so that we can get a better idea of it.
