I have completed the topics quiz for unit 4 of ROS in 5 days but it keeps giving me a mark of 1. I have tested out the program multiple times and I do not understand what is wrong. I can see in the simulation that the robot avoids the wall and when I do rostopic echo /cmd_vel, I can see information being published to the topic. However I keep getting zero marks for these. Can someone please help me? I am so lost and my professor doesn’t understand my mark either.
Hi @joubr13,
- Can you run
catkin_makesuccessfully? When I tried it didn’t complete because of an error. - Can you run
roslaunch topics_quiz topics_quiz.launchsuccessfully? Here’s what I got when I tried:
user:~$ roslaunch topics_quiz topics_quiz.launch
... logging to /home/user/.ros/log/559216fa-0e02-11eb-be1b-0242c0a82008/roslaunch-6_xterm-1307.log
Press Ctrl-C to interrupt
Invalid roslaunch XML syntax: no element found: line 8, column 4
With these errors in place, it’s not surprising that the quiz is failing.
Next steps:
- Please fix the errors above and any that comes up. You need to test your code using
roslaunch, not just run the python code. And, of course, your package needs to compile. - Please check that you have created the package exactly as specified. Otherwise, the grader could mark you down even if your package works.
