Hello dear,
As I understand from this amazing platform till now(where I finish 45% of ROS basics in 5 days with python), that the procedure of obstacles avoidance is:
- get the distance for front/right/left from the msg that send by topic (/scan)
- use python code to make procedure
- send this procedure via cml_vel to move the robot
from my experience, many LIDAR sensors don’t offer their data by sample way,
for that I was asking is their any industrial LIDAR recommended that offer easy way to extract the distance for each angle?
My 2’nd question:
Do you recommend use depth camera for obstacles avoidance?
is there any recommended modules?
what about realsense D435 from intel?
Thanks.
Hello @aameralshamy3 ,
I’m not sure if I fully understand your first question, but in ROS, the laser data is provided using a LaserScan message (sensor_msgs/LaserScan Documentation). With this message, it’s pretty straightforward to extract the angles data using the angle_min, angle_max, and angle_increment fields. Here you have some models: https://www.roscomponents.com/es/20-lidar-escaner-laser
As for the Depth Camera question, it really depends on the application you want to build. For mobile robots, it’s usually enough with a Laser sensor for doing Object Avoidance, so I wouldn’t recommend it. But yes, the D435 from Intel is a good option in any case: https://www.roscomponents.com/en/21-cameras
Thanks you for your reply @albertoezquerro
in my application I have mobile robot with low speed,I need to provide it with avoidance obstacles ability and implement object detection, do you think I can do both tasks depending on the depth camera data analysis?
If your answer is no, do you recommend any reliable Lidar module with price less than 1000 USD ?
do you think 2d 360 digree Lidar good or 3d one best?
Yes, you should be able to do both obstacle avoidance and object detection using a Depth camera. You can also convert the PointCloud data of the Depth camera into LaserScan data (using something like this: http://wiki.ros.org/pointcloud_to_laserscan) which you can directly feed into the ROS Navigation stack.
@albertoezquerro
Thank you very much alberto
