Hi RobotIgnite, All,
I’m trying to launch the PR2 robot from the ROS wiki (http://wiki.ros.org/pr2_robot), I had downloaded the https://github.com/PR2/pr2_robot.git to the catkin_ws/src environment using git clone,
when I do the catkin_make, I got the following errors:
inmoov@ubuntu:~$ cd catkin_ws/
inmoov@ubuntu:~/catkin_ws$ catkin_make
Base path: /home/inmoov/catkin_ws
Source space: /home/inmoov/catkin_ws/src
Build space: /home/inmoov/catkin_ws/build
Devel space: /home/inmoov/catkin_ws/devel
Install space: /home/inmoov/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/inmoov/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/inmoov/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/inmoov/catkin_ws/devel;/opt/ros/kinetic
-- This workspace overlays: /home/inmoov/catkin_ws/devel;/opt/ros/kinetic
-- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.12", minimum required is "2")
-- Using PYTHON_EXECUTABLE: /usr/bin/python2
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/inmoov/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gmock': gtests will be built
-- Found gmock sources under '/usr/src/gmock': gmock will be built
-- Found PythonInterp: /usr/bin/python2 (found version "2.7.12")
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.20
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 14 packages in topological order:
-- ~~ - imu_monitor
-- ~~ - inmoov_bringup
-- ~~ - inmoov_description
-- ~~ - inmoov_firmware
-- ~~ - inmoov_meshes
-- ~~ - inmoov_tools
-- ~~ - pr2_robot (metapackage)
-- ~~ - inmoov_msgs
-- ~~ - pr2_computer_monitor
-- ~~ - pr2_run_stop_auto_restart
-- ~~ - pr2_bringup
-- ~~ - pr2_controller_configuration
-- ~~ - pr2_ethercat
-- ~~ - pr2_camera_synchronizer
-- +++ processing catkin package: 'imu_monitor'
-- ==> add_subdirectory(pr2_robot/imu_monitor)
-- +++ processing catkin package: 'inmoov_bringup'
-- ==> add_subdirectory(inmoov_ros/inmoov_bringup)
-- +++ processing catkin package: 'inmoov_description'
-- ==> add_subdirectory(inmoov_ros/inmoov_description)
-- +++ processing catkin package: 'inmoov_firmware'
-- ==> add_subdirectory(inmoov_ros/inmoov_firmware)
-- +++ processing catkin package: 'inmoov_meshes'
-- ==> add_subdirectory(inmoov_ros/inmoov_meshes)
-- +++ processing catkin package: 'inmoov_tools'
-- ==> add_subdirectory(inmoov_ros/inmoov_tools)
-- +++ processing catkin metapackage: 'pr2_robot'
-- ==> add_subdirectory(pr2_robot/pr2_robot)
-- +++ processing catkin package: 'inmoov_msgs'
-- ==> add_subdirectory(inmoov_ros/inmoov_msgs)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- inmoov_msgs: 3 messages, 1 services
-- +++ processing catkin package: 'pr2_computer_monitor'
-- ==> add_subdirectory(pr2_robot/pr2_computer_monitor)
-- +++ processing catkin package: 'pr2_run_stop_auto_restart'
-- ==> add_subdirectory(pr2_robot/pr2_run_stop_auto_restart)
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
Could not find a package configuration file provided by "pr2_msgs" with any
of the following names:
pr2_msgsConfig.cmake
pr2_msgs-config.cmake
Add the installation prefix of "pr2_msgs" to CMAKE_PREFIX_PATH or set
"pr2_msgs_DIR" to a directory containing one of the above files. If
"pr2_msgs" provides a separate development package or SDK, be sure it has
been installed.
pr2_robot/pr2_run_stop_auto_restart/CMakeLists.txt:6 (find_package)
-- Could not find the required component 'pr2_msgs'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
been installed.
-- Configuring incomplete, errors occurred!
See also "/home/inmoov/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/inmoov/catkin_ws/build/CMakeFiles/CMakeError.log".
Makefile:612: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
screenshot:
Are you able to assist please?
I really want to dig into this with the help of RobotIgnite academy on how I can reuse PR2 robot on my own robot,
Thank you,
Kind Regards
@wai.mak
