ROS1 Bridge -EXTRA?
Suddenly this is at the front of my ROSject. I don’t remember it being there before. I had started the lesson already. Is this an error? All other help topics on the ROS1 Bridge are from 2022?
This probably means that you have an outdated version of the rosject. You don’t need the ROS1 bridge anymore.
  1. If you have any progress in your rosject, make sure to download it to your computer so you can reupload it later
  2. Delete your current rosject.
  3. Get a new copy by clicking this link: https://app.theconstruct.ai/l/404c2ba6/
  4. Reupload the work you downloaded, if any.
Okay - I will do that. I’m not sure how I going half way through the Wall Follower project - before that popped up, it’s like it regressed. But I can copy down and reload
Wait - I think I see what happened! The notebook is fine when I open the rosject. However, I was working on a dual monitor set up yesterday and I popped the notebook out of the frame so I could refer to it while coding, etc. That’s when the ROS Bridge popped up. I’m on the small setup today, so it won’t matter. However, you might want to check that. It’s obviously opening the wrong notebook.
