Hi, @staff
I’m still curious about the Action Client code issue: executor.spin() written on 6.2.2 How to call an Action Server
It worked as instructed with executor.spin_some().
However, I found that the class MultiThreadedExecutor doesn’t have spin_some() as the member function.
Please see attached link below where im looking for:
rclcpp::executors::MultiThreadedExecutor Class Reference
I also checked with multi_threaded_executor.hpp. and spin_some() doesn’t exist anywhere.
Then why did it work correctly?
I am still new on C++ & ROS, so if you know the reason I would like to understand.
And is this the reason why you haven’t updated it yet?
This is the entire current script for your information:
action_client.cpp
#include <inttypes.h>
#include <memory>
#include <string>
#include <iostream>
#include "t3_action_msg/action/move.hpp"
#include "rclcpp/rclcpp.hpp"
#include "rclcpp_action/rclcpp_action.hpp"
class MyActionClient : public rclcpp::Node
public:
using Move = t3_action_msg::action::Move;
using GoalHandleMove = rclcpp_action::ClientGoalHandle<Move>;
explicit MyActionClient(const rclcpp::NodeOptions & node_options = rclcpp::NodeOptions())
: Node("my_action_client", node_options), goal_done_(false)
this->client_ptr_ = rclcpp_action::create_client<Move>(
this->get_node_base_interface(),
this->get_node_graph_interface(),
this->get_node_logging_interface(),
this->get_node_waitables_interface(),
"move_robot_as");
this->timer_ = this->create_wall_timer(
std::chrono::milliseconds(500),
std::bind(&MyActionClient::send_goal, this));
bool is_goal_done() const
return this->goal_done_;
void send_goal()
using namespace std::placeholders;
this->timer_->cancel();
this->goal_done_ = false;
if (!this->client_ptr_) {
RCLCPP_ERROR(this->get_logger(), "Action client not initialized");
if (!this->client_ptr_->wait_for_action_server(std::chrono::seconds(10))) {
RCLCPP_ERROR(this->get_logger(), "Action server not available after waiting");
this->goal_done_ = true;
return;
auto goal_msg = Move::Goal();
goal_msg.secs = 5;
RCLCPP_INFO(this->get_logger(), "Sending goal");
auto send_goal_options = rclcpp_action::Client<Move>::SendGoalOptions();
send_goal_options.goal_response_callback =
std::bind(&MyActionClient::goal_response_callback, this, _1);
send_goal_options.feedback_callback =
std::bind(&MyActionClient::feedback_callback, this, _1, _2);
send_goal_options.result_callback =
std::bind(&MyActionClient::result_callback, this, _1);
auto goal_handle_future = this->client_ptr_->async_send_goal(goal_msg, send_goal_options);
private:
rclcpp_action::Client<Move>::SharedPtr client_ptr_;
bool goal_done_;
void goal_response_callback(const GoalHandleMove::SharedPtr & goal_handle)
if (!goal_handle) {
RCLCPP_ERROR(this->get_logger(), "Goal was rejected by server");
} else {
RCLCPP_INFO(this->get_logger(), "Goal accepted by server, waiting for result");
void feedback_callback(
GoalHandleMove::SharedPtr,
const std::shared_ptr<const Move::Feedback> feedback)
RCLCPP_INFO(
this->get_logger(), "Feedback received: %s", feedback->feedback.c_str());
void result_callback(const GoalHandleMove::WrappedResult & result)
switch (result.code) {
case rclcpp_action::ResultCode::SUCCEEDED:
break;
case rclcpp_action::ResultCode::ABORTED:
RCLCPP_ERROR(this->get_logger(), "Goal was aborted");
return;
case rclcpp_action::ResultCode::CANCELED:
RCLCPP_ERROR(this->get_logger(), "Goal was canceled");
return;
default:
RCLCPP_ERROR(this->get_logger(), "Unknown result code");
return;
RCLCPP_INFO(this->get_logger(), "Result received: %s", result.result->status.c_str());
}; // class MyActionClient
int main(int argc, char ** argv)
rclcpp::init(argc, argv);
auto action_client = std::make_shared<MyActionClient>();
rclcpp::executors::MultiThreadedExecutor executor;
executor.add_node(action_client);
while (!action_client->is_goal_done()) {
executor.spin(); //this is where i am talking about
rclcpp::shutdown();
return 0;
