What happens if you are unable to complete the quiz after 5 attempts?
Hi @costell ,
You have two options:
- If you have not looked into the solution yet and your code is now working correctly, you could request TheConstruct team for extra attempts.
- If you have looked into the solution and you have used all your 5 attempts and if your code is working or not, then you can never complete it. Just proceed with the course. You might be given a chance to complete the quiz after you complete the course.
That is what I can say, you can consult with TheConstruct team for more info.
Okay, I had looked at the solution after my 5th attempt, and it ended up being that I named my node packet incorrectly. Thanks for your input.
